It is currently Mon Jun 29, 2026 3:38 am
PostPosted: Mon Nov 20, 2006 11:52 pm
hi, Ive got a 1980 chevy luv truck with a 3" body lift on it. I Jacked up the torsion bars up about 2-3 " and put 28" tires under it. I was wondering if there was a place where you could buy a longer leaf shackle, or I also heard someone tell me about an Add-a-leaf kit. Are they worth puttin on there? I dont know. Any info would be appreciated. Thanks, Nick.
Thanks, Nick.
PostPosted: Tue Nov 21, 2006 4:39 pm
Banishment Pending
Summit has several add-a-leaf kits that will work with the Luv, but I wouldn't go that route personally as it make the back end a whole lot stiffer. longer rear shackles would be the way to go, this site has them http://www.independent4x.com or you could make your own, or go the auto parts store route. also shackles for Toyota mini trucks should work as well as they have the same sized springs.
PostPosted: Tue Nov 21, 2006 5:03 pm
Not sure if this helps but I added air bags to my 02 K2500HD to level out the rear.
PostPosted: Tue Nov 21, 2006 11:34 pm
Banishment Pending
that would work too, would have to use a universal kit or one built for Isuzu pickups/leaf sprung suv's
PostPosted: Thu Oct 25, 2007 11:13 pm
I am new to Luvs... Hoe do you adjust the torsion to increase ride highth in the 80 4x4? If I max it out, will I still keep driveability?
PostPosted: Fri Oct 26, 2007 11:41 am
Banishment Pending
HOLY OLD POST BATMAN!!! 8O
here's a run down on how to do the T-bar lift
Linky to Planetisuzoo write up
PostPosted: Sat Oct 27, 2007 12:01 am
That means he was using the search icon. Good job.
