It is currently Tue May 19, 2026 4:04 pm
PostPosted: Fri Sep 01, 2006 10:58 pm
for a 2'' do you mess with the steering or what does this all entail
hey Zane can i see those pics again if handy????
any info would be highly appreciated
PostPosted: Sat Sep 02, 2006 1:04 pm
i don't think you have to mess with the steering, that is usually on the 3" than you have an ugly lift and a bunch of xtra problems. i did a 2" on my s-10 by myself in an afternoon, just make sure that no wires are going to be stretched or kinked, or brake lines, maybe have someone look around as you're liftin it up. 8)
PostPosted: Sat Sep 02, 2006 10:53 pm
great so basically a bolt n' block procedure?
PostPosted: Sun Sep 03, 2006 12:19 am
pretty much, just make sure nothing is stretching and stressing and if it is you can make little "drop down" brackets to relieve the tension.
PostPosted: Sun Sep 03, 2006 10:31 pm
so hows your truck comin? lookin pretty good as far as I seen in some pictures
PostPosted: Sun Sep 03, 2006 10:50 pm
The kits usually come with a spacer that goes under the dash and above the steering column. It is about a half inch thick and goes on the column mount in between the ignition and the headlight switch.
Watch the hard fuel lines where they come off the bottom of the cab, you might want to get them loose from their hold downs and sort them out after the lift is in. In general, just loosen up some of the attachment points where lines and wires are held to the frame or body near where they cross between the two. I think I actually had more trouble with the shifters than anything else, but I was fixing a poorly done 1 1/2 inch lift not installing from scratch.
PostPosted: Sun Sep 03, 2006 11:09 pm
hey lets see some pics of you truck
PostPosted: Mon Sep 04, 2006 11:05 pm
I just got the 2'' kit and it had a steering plate and said to cut the floor
If anybody else recently put on a 2'' please chime in with some info
