It is currently Fri Jun 19, 2026 2:47 pm
PostPosted: Mon Jul 16, 2007 8:09 pm
:P
PostPosted: Mon Aug 20, 2007 5:09 pm
nice truck,thats about the same project im planning on for my luv, gonna use toyota axles though.
PostPosted: Mon Aug 20, 2007 7:36 pm
I have seen a guy make half doors on differnt trucks and he cuts them down to look like Jeep doors. With a lower section cut down in the doors ie: Soft top CJ jeep doors. He said it gives him and others a better look at the trail, tires ect.
PostPosted: Wed Sep 05, 2007 6:55 pm
Hopefully mine will turn out as good as yours. I'm not going to use full size rear ends though. I am going to use the rear ends from a Toyota.
1980 LUV Mikado 4X4
2003 Chevy S10
PostPosted: Wed Sep 12, 2007 6:36 pm
I wanna put my luv on full size axles out from under a 79 k5 blazer, but the steering is what im concerned about! Can any one help me out on this delima please......BUZZ
PostPosted: Fri Oct 19, 2007 12:15 pm
are you going to use the hole frame or just the axles and are they 1/2 or 3/4 ton ether way you can us the gear box from the k5 and do the x over steering thats what i am going to do on my k5 so if you need more let me know
dangerous-toys4life
75 k-5 2x
94 king cab
PostPosted: Sat Oct 20, 2007 12:51 pm
the 10 bolt front/14bolt rear is standard 3/4 ton running gear from late 70's to mid 80's I have ran the same stuff with 42 inch swampers on a 5000# truck and don't have any trouble.
72 luv v-8 owned since 16!
240" rear engine dragster
[color=#FF8000]
29 dodge 4 dr sedan (project)
PostPosted: Wed Sep 24, 2008 12:02 pm
Nice lookin truck! What's the size of those tires?
PostPosted: Wed Sep 24, 2008 8:23 pm
post resurrector
How big of lift springs did you use.
'80 luv 4wd 6.0 vortec hurst 4spd process of lifting
'69 f-100 4wd 14" lift and 44s
'03 f-150 4dr 4wd daily
BOOMER SOONER!!!
PostPosted: Sun Oct 05, 2008 10:12 pm
tires are 39.5
stock height springs wagoneer front 63" chevy rear. custom mounts
took it to the rubicon this weekend. when my buddy gives me the pics i'll post some
PostPosted: Tue Oct 07, 2008 11:19 am
Odd question but can you tell me the type and size of those Firestone tires in your first pic?
Thanks..
A.j.
PostPosted: Tue Oct 07, 2008 10:07 pm
235/75/15
