It is currently Sat Jun 13, 2026 4:34 pm
Post new topic Reply to topic  [ 26 posts ]  Go to page Previous  1, 2
PostPosted: Fri Apr 06, 2007 11:23 am
Banishment Pending
depends on the back spacing of the rim and what truck the rims came off of. I'll put it to ya this way..stick Isuzu Trooper rims (circa 84-91) have a neutral offset...thats what your looking for.
PostPosted: Thu May 10, 2007 2:40 am
What is the correct stock size for a 4x4 tire? I've got 195/70's on it now. I was following the wife on 1-5 tonight with a new bunkbed in back, and she phoned to ask if I was OK. Apparently she was only doing 60 and I was lagging behind. One profile size is only 3% difference @ 60 mph and my speedo said about 67, so something is way off.
I have 195/75R14's on the 2x...should I put them on the 4x4? Or are those too small too?
 Post subject: .
PostPosted: Thu May 10, 2007 8:21 am
mine are 225/70r14 on stock 4x4 wheels
FIAA: Color Guard
PostPosted: Fri May 11, 2007 1:44 pm
195/75-R14 is about as close as you can get to the original stock size. 4x4s came stock with a slightly wider tire I believe, but the same diameter. I've run 205/75s and the speedo was close enough to dead on I never noticed.
PostPosted: Mon Jun 18, 2007 11:13 am
My 81 4x4 stock size was 205/75/14 I am now running 225/75/15 on the front and H78-15 on the rear.
Rigel
81 LUV 4x4 Red Was a heavy hauler now is back to mostly stock config.
http://www.Rigeltech.com
 Post subject: Re: Tires
PostPosted: Thu Oct 09, 2008 3:10 pm
post resurrector
I was able to fit 33'' 12.50 mudders on my '80 by tweeking the tb's and a add a leaf in the rear. 8)
'80 luv 4wd 6.0 vortec hurst 4spd process of lifting
'69 f-100 4wd 14" lift and 44s
'03 f-150 4dr 4wd daily
BOOMER SOONER!!!
