It is currently Tue May 19, 2026 4:57 pm
 Post subject: 5 speed tranny
PostPosted: Thu Oct 26, 2006 1:20 pm
i have heard that a 5 speed from a 1.9 litre trooper would fit the luv with a little driveshaft work. its 4 by, so i cant use an impulse tranny. is that rumore true? can i use the trooper tranny?
'79 Chev 4X4 LUV baby!
2006 Chevy Cobalt, *modified...
64 Dodge Dart GT
"You like this car???...."
PostPosted: Thu Oct 26, 2006 1:38 pm
I believe most of the 1.9L Troopers had a 4spd in them. What you are looking for is a 2.3L Trooper, 86 or 87. Basically just find a Trooper with a carb (not fuel injection) and a 5spd and you should be set. The 5spd trans is longer than the LUV 4spd though, and mounts a little differently. You'll need the driveline shortened and a little bit of welding/cutting for mounts, but other than that it is pretty much bolt on.
PostPosted: Fri Oct 27, 2006 2:37 am
yup all the troopers with G-engines ran a 4speed. I love the little G-engines but i dont see it having enough HP to keep a brick of a Trooper going in OD... :lol:
 Post subject: Example
PostPosted: Mon Jan 01, 2007 8:01 pm
Search my posts and you'll find some pictures from my 5 speed conversion on a 79 4x4 with an Isuzu Trooper Tranny.
Mine's been in the garage too long to try to remember any details...
-DK
