It is currently Sat Jun 13, 2026 7:46 am
PostPosted: Mon Apr 17, 2006 1:58 pm
Where can I get a 3" body lift kit for a 79 Luv 4x4? Does lifting the body make installing a V8 easier? Thanks.
79 4x4 LUV
PostPosted: Mon Apr 17, 2006 3:00 pm
Banishment Pending
Performance Accessories (SP?) sells them for about $100
http://www.jackit.com has them as does JC Whitney
as far as making it easier to fit a V8 in a 4x4, I have no clue, in theory it gives you and extra 3" of clarence to play around with under the hood, but i don't know it thats enough for a V8 to clear the front axle
PostPosted: Mon Apr 17, 2006 10:58 pm
The extra room under the hood and in the tunnel certainly couldn't hurt. I don't think I'd hook a V8 up to the stock front end though. If the CVs didn't break, the shafts would, or the hubs, or the third member.
PostPosted: Tue Apr 18, 2006 10:18 am
I do not plan on keeping the stock drivetrain. I have picked up a Dana 44 for the front and a 12 bolt for the rear. I am only putting a 305 in it backed by a TH350 and NP 205 Transfercase. Still have to collect all the other parts for the swap.
79 4x4 LUV
PostPosted: Tue Apr 18, 2006 1:10 pm
Banishment Pending
this does bring up an interesting idea though, with a 3" BL you could in theory have a enough room to drop in a V8, but if thats the case that also means you'd have enough room to drop in a 4.3 V6 (which is a much more 8-bolt friendly than a V8, still wouldn't want to keep there for long, but It wouldn't be too bad for temporary use i.e. using it while waiting for parts to come in for a SAS) brings up some interesting stuff to consider
 Post subject: CV axles?
PostPosted: Thu Jun 29, 2006 1:54 am
Im not sure if you are talking about when you say cv shafts. are you refering to the halfshafts in the front end or actual cv shafts like a front wheel indelpendent suspension car is? My friend just recently bought a 1980 chevy luv 4x4 with a solid front axle with a 1.8L and a manual 4 speed. My brat has 4 wheel independent suspension with primary front wheel drive with an on demand transfer case so i have cv shafts front and back. my friends luv has u-joint looking things going to his wheels.
1981 Subaru BRAT (Bi-drive Recreational All terrain Transporter) and hopefully a chevy luv to some day
