It is currently Sat Jun 13, 2026 7:53 am
 Post subject: 4 high problem
PostPosted: Thu Feb 09, 2006 8:54 pm
my 4 high gear slips out when a go up a hill or start to go fast I have been tieing it so it will stay but its a pain in the ass what is the problem and how do I fix it
If you cant find it grind it
79 4x4 1.8 liter
69 Jeepster comando v6
 Post subject: Re: 4 high problem
PostPosted: Thu Feb 09, 2006 11:10 pm
I'm not a tranny expert, but my old trans had that problem in reverse gear. The syncros were worn. If that is the problem, then you will need a partial rebuild, or full rebuild, or another tranny.
PostPosted: Thu Feb 09, 2006 11:29 pm
or just a good bungee cord to keep it in gear.... 8O
PostPosted: Fri Feb 10, 2006 12:20 am
make sure the shift lever is not hitting the floor boards, it might not be going all the way in gear
PostPosted: Fri Feb 10, 2006 10:10 am
Thats what I have been doing to
79 4x4 1.8 liter
PostPosted: Sat Feb 11, 2006 11:10 am
If you have any body lift that might be a contributing factor too. I had to cut quite a bit around my 4x4 shifter to get it to clear and stay in 4LO. Everytime I backed up it would pop out.
PostPosted: Sat Feb 11, 2006 11:42 am
My 4 lo is fine I have no body lift its just dose not lock in 4h
79 4x4 1.8 liter
PostPosted: Sat Feb 11, 2006 3:18 pm
Banishment Pending
sounds like you need a t-case rebuild, shouldn't be too hard if you got a manual.
PostPosted: Sat Feb 11, 2006 9:41 pm
there should be a spring that holds the shifter in gear on the shifter. See if thats still there. Just pull the boot up and you should see it there on the boot thats on the transfer case.
PostPosted: Sat Feb 11, 2006 10:55 pm
Chavy, is sounds to me like the trans will need a repair. The syncros on 4th gear have worn out. As long as it is out you might as well rebuild the whole thing so you know it's all done and good. :wink:
PostPosted: Mon Feb 27, 2006 7:35 am
DEFINETLY A SYNCRO...................
