It is currently Thu Jun 18, 2026 5:44 am
PostPosted: Sun May 26, 2019 4:48 pm
Ok, on my 81 4x4 my mechanic is suggesting moving the rear leaf springs to the topside of the rear end vs the bottom.
He is also suggesting getting a Toyota straight axel front end for the front.
We are taking the bed off and putting a flat bed stake body on it.
Anyway, he is saying these two mods will give me more ground clearance.
Anyone ever done these?
PostPosted: Mon May 27, 2019 3:55 pm
Yes, but not with a Toyota axle. Back before factory mini truck 4x4s hit the market in 1979 this was a popular mod, even available from dealers, which is where I got mine.
PostPosted: Mon May 27, 2019 5:34 pm
So what did you use?
PostPosted: Mon May 27, 2019 9:21 pm
It's a Dana 30, probably from a Jeep, modified to use the stock LUV 6-bolt rotors & calipers. Every 4x4 conversion kit of the day used a similar axle, LUVs, Ford Couriers & Datsuns used 6-bolt fronts to match the stock rears, Toyota used large 5-bolt fronts & a small-to-large 5-bolt adapter in the rear. The stock 2wd trannies were used along with divorced Dana 20 or Dana 300 t-cases. Everything came in kit form along with instructions, or you could order the kit pre-installed through the various dealerships. These haven't been available for over 30 years.
The easiest swap now is a '79-'85 4x4 Toyota pickup/4Runner front axle- it's the right width & lug pattern & probably 4.10 ratio to let you retain the stock engine/tranny/rear axle.
PostPosted: Mon Jun 08, 2020 9:59 am
Here is a Baja 4-Wheel Drive conversion brochure.
PostPosted: Sun Jun 14, 2020 10:56 am
Have never done it but this truck has an all Toyota suspension conversion.
Don't know much about it as this was back in the early 90's and I tried to buy the truck twice as it is one of the nicest LUV's I have ever seen.
ps didn't notice the OP is over a year old, oh well.
PostPosted: Thu Nov 12, 2020 8:30 pm
Any chance I could buy a stock CV axle and hub assembly
