It is currently Tue May 19, 2026 1:41 pm
 Post subject: clicking in front end
PostPosted: Sat Jan 29, 2011 12:01 am
I have an '80 LUV. when driving or coasting forward or back there is a clicking noise coming from the front end. where should I start looking? Thanks.
PostPosted: Sat Jan 29, 2011 1:00 am
The front end...
On a serious note, is it a 2x4, 4x4?
PostPosted: Sat Jan 29, 2011 10:19 am
it's a 4x4. the click happens whether or not the hubs are in and seems to happen at slow or faster speed, even just pushing it across the shop floor. I haven't taken the front brakes or anything off yet to check but it doesn't sound like it's in the brakes.
PostPosted: Sun Jan 30, 2011 10:16 am
if the shafts aren't rotating, it may be in the front case. . . . Although it shouldn't be rotating if it's not engaged...
PostPosted: Sat Feb 26, 2011 7:23 pm
Mine recently did the same thing behind one of the brake pads theres a thin metal plate that vibrated loose hence the rattle.
PostPosted: Thu Mar 03, 2011 8:11 pm
If you have a shop jack up all four wheels and let it idle in gear.
1980 4x4
