It is currently Tue May 19, 2026 1:42 pm
 Post subject: Rear locker for 4x4?
PostPosted: Fri Feb 18, 2011 9:02 am
Hey Guys,
Does anyone know if there is such a thing as a rear locker for a 4x4?
 Post subject: Re: Rear locker for 4x4?
PostPosted: Fri Feb 18, 2011 11:27 am
A LUV 4x4? Can be done, I've got one (two actually, Trooper has the same rear, just different ratio). There is also one LSD option that can be retrofitted.
PostPosted: Sun Feb 20, 2011 12:37 am
yea that LSD is in a RWD isuzu turbo car
87/88 or 88/89 :?: never can remember, yea very few and hard to find.........
only auto to get a LSD for the 10 bolt rear axil :(
if you find one it also has a funky 3.90 geared rear end and a 20.0% O\D trans all the other O\D MSG tranys are 14.5%
GRANTED THAT STUFF IS WORTH LESS IN A 4wd.
never-the-less its in demand if found for a 2WD ride. :P
86trooperT/D 2.2
84 L\B 4x4Diesel LS 2.2
86 L\B 4X4 gas 5 speed 2.3
PostPosted: Sun Feb 20, 2011 9:50 pm
okay waitttt......
how do you do that LSD swap!!!! is it just a direct swap over?
PostPosted: Sun Feb 20, 2011 10:48 pm
yep, its the only bolt in LSD that Isuzu offered state side in the rear 10 bolt......
only the turbo RWD cars have the LSD,
it does not have to be a turbo to have the 3.90 gears or 20% O\D 2WD trans.
86trooperT/D 2.2
PostPosted: Mon Feb 21, 2011 8:32 am
To change the rear carrier to LSD you first have to have the LSD carrier from a RWD Turbo Impulse (mid 80's through 1989). If the LSD carrier is still attached to the stock Impulse 3.90 gears you have to remove it, then remove your stock carrier, attach the 4.10 ring gear to the LSD carrier and install the LSD carrier/stock ring gear into your stock housing, which requires shimming the new carrier to obtain the proper ring and pinion contact pattern. It's not a complete differential tear down and rebuild since the pinion gear was not disturbed, but it's probably best left to someone with differential rebuild experience. One down side, you have a 20 year old LSD, the clutches may or may not be in good shape. On the upside if it works well you have way better traction, probably out $300-$400.
PostPosted: Mon Feb 21, 2011 1:43 pm
im gonna have to look into that. i have a friend at work that had an 88 impulse turbo as his drift car for a while. i knwo he still has the turbo manifolds and turbo and such i was thinking about making work on my luv. if he still has the tranny and lsd im gonna have to get those off him too X^D
