It is currently Tue May 19, 2026 1:41 pm
PostPosted: Thu Dec 23, 2010 8:20 pm
will it fit or do i need whole axle ?
PostPosted: Thu Dec 23, 2010 8:24 pm
The '86 did not come with rear disks.
PostPosted: Fri Dec 24, 2010 10:30 am
i ment 89 sry
PostPosted: Fri Dec 24, 2010 12:42 pm
The whole axle assembly can be made to fit, but it's 4" wider than your stock one and the driveshaft flange is different, as is the p-brake setup.
PostPosted: Sat Dec 25, 2010 2:32 am
so no just pulling the axle and putting it on the old luv axle
PostPosted: Sat Dec 25, 2010 12:20 pm
The disk rears are 12-bolt Isuzu, they are a much heavier rear with larger axle tubes- and everything else- than the Isuzu 10-bolt in all LUVs. Basically nothing interchanges between the two.
PostPosted: Sun Feb 20, 2011 1:06 am
you'd have a gearing change too, if it came from a trooper since there 4.55 or 4.77 in 88/91
the isuzu 4WD trucks 88/95 had 4.11s in some models "if i remember right", its gotta come from a truck thats 2.6L or 3.1L V-6 powered.
2.3L 2WD trucks where still 10 bolt. 1988 up, 2.6L is the smallest 4WD engine.
the only gears for the front 8 bolt used in any luv, pup or trooper 4WD, 1979/1987 is 4.11s and 4.55s :(
86trooperT/D 2.2
84 L\B 4x4Diesel LS 2.2
86 L\B 4X4 gas 5 speed 2.3
