It is currently Tue May 19, 2026 1:40 pm
PostPosted: Mon Feb 22, 2010 10:33 pm
hey guys, i've been reading my service manual but am having a tough time getting a straight answer
i need to get the broken wheel studs out, but i need to know if i have to disassemble the hub assembly to get the rotor and studs out? or can i get them out without doing that?
PostPosted: Tue Feb 23, 2010 12:00 am
You will have to remove the Hub from the spindle then unbolt the rotor, press the bronken studs out of the Hub, and pressin the new ones in.
PostPosted: Tue Feb 23, 2010 8:17 pm
sooo, no disassembly of the hub mechanism is required?
PostPosted: Tue Feb 23, 2010 10:09 pm
Yes it is, that is what he meant by unbolting the rotor from the hub...
PostPosted: Wed Feb 24, 2010 12:07 am
ok, just making sure i understood that correctly.
i'll be doing that tomorrow then
