It is currently Tue May 19, 2026 2:40 pm
 Post subject: Converting 4x4 into 2WD
PostPosted: Tue Oct 14, 2008 10:47 pm
Hello there i am new to this website. I love chevy luv trucks and have had several in my life. The last two i had were both 2WD, but for good reasons i had to give both of them up. I decided to look for another luv, but they are hard to find. I did happen to find a 4x4 and would like to purchase it and convert it to 2WD and was wondering how hard it would be and what exactly i would need to do to convert it to 2WD?
PostPosted: Wed Oct 15, 2008 3:17 am
Australian LUV Guru
Why would you want to convert it to 2wd :?:
1980 4x4 KBD40 ISUZU/Chev Luv
PostPosted: Wed Oct 15, 2008 8:17 pm
Where are you located?
PostPosted: Thu Oct 16, 2008 10:14 pm
The reason why i want to convert it to 2WD is because i plan on fixing it up into a show truck. I am located in Copperas Cove, Texas.
PostPosted: Fri Oct 17, 2008 3:08 am
Australian LUV Guru
If your wanting to build a 2wd show truck i suggest you don't use a converted 4wd. There are differences between the frames even after the 4wd parts are removed that will hold you back.
PostPosted: Fri Oct 17, 2008 6:52 am
post resurrector
Why dont you just jack it up and still make it a show truck.
'80 luv 4wd 6.0 vortec hurst 4spd process of lifting
'69 f-100 4wd 14" lift and 44s
'03 f-150 4dr 4wd daily
BOOMER SOONER!!!
PostPosted: Tue Nov 04, 2008 4:55 pm
I am doing the same, came across a deal i couldnt pass up and now I am bagging it as we speak, alittle harder but am selling everything under the body except for the frame
