It is currently Tue May 19, 2026 3:17 pm
 Post subject: suspension lift
PostPosted: Thu Nov 01, 2007 8:26 pm
does any body know how to put a front suspension lift on a 79 luv i want to lift it about 6 inches or more or where i can find a kit i was looking at some of the other luvs and noticed they did a toyota swap is that the only way to fit the 38s
 Post subject: .
PostPosted: Thu Nov 01, 2007 9:05 pm
Pretty much, all you can do is torsion bar lift for front, shackles and/or add-a-leaf for the rear and body lift.... unless you get real creative like Kevin Whitten... and you got lotsa tools :)
http://www.luvtruck.com/Gallery/KevinWh ... index.html
FIAA: Color Guard
 Post subject: Re: .
PostPosted: Fri Nov 02, 2007 9:15 am
8O That's fricken schweet!
PostPosted: Fri Nov 02, 2007 12:35 pm
To lift a luv that much I would do a solid from axle swap. alot more lift and a lot better result. The end result will be alot better and your going to be alot happier with it. But it will require alot more work. I did one on my 1995 toyota 4x4.
Craig
PostPosted: Fri Dec 21, 2007 11:03 pm
my luv has a 2 inch body lift and a four inch suspension lift totalling 6 inches and it has 33's and i dont think you could fit 38's with only 6 inches of lift unless you started cutting stuff.
PostPosted: Sat Dec 22, 2007 3:23 am
Nice lookin' truck!
 Post subject: .
PostPosted: Sat Dec 22, 2007 10:35 am
How'd you do the suspension? T-bars and shackles, or a kit?
FIAA: Color Guard
PostPosted: Fri Jan 18, 2008 5:43 pm
Can you get away with a 2 inch suspension lift without putting too much stress on the suspension? And what size tires could you put under a 2 inch lift?
PostPosted: Sat Jan 19, 2008 2:24 am
it depends on what you do, if you are cranking the torsion bars, then yes, that puts a lot of added (unecessary and worthless in my opinion) stress on the suspension. If it is a true suspension lift it shouldn't be putting any more stress on the suspension than normal, the tires and your foot are going to dictate the amount of stress the susp. sees :wink:
FYI: I fit 39.5s on less than 4" of lift.... not without some mods though :oops: :lol: :lol: :lol:
PostPosted: Sat Jan 26, 2008 7:18 pm
what about re indexing the front torsion bars? That way you get the same ride quality as stock and no added stress right?
(PLATINUM STREET RODS)
Deming, NM
PostPosted: Sat Feb 02, 2008 2:09 pm
What's re-indexing mean?
 Post subject: .
PostPosted: Sat Feb 02, 2008 2:10 pm
http://www.planetisuzoo.com/articles.ht ... Adjustment
FIAA: Color Guard
PostPosted: Tue Feb 05, 2008 11:01 pm
Check out the sticky in Body And Chassis upgrade.
A Trooper A arm will help raise the front in on a Luv
http://forums.luvtruck.com/viewtopic.php?t=16042
PostPosted: Wed Feb 06, 2008 10:33 am
But because its double A-arm, any lifting is going to add stress and later geometry.
When lifting Undo all the bolts thru the suspension bushings then sit the cars weight down on the suspension then do the tru bolts up on the bushes. This will help prevent overloading the bushes.
Bob.
 Post subject: Re: suspension lift
PostPosted: Thu Oct 09, 2008 8:16 am
post resurrector
I would just find you some one ton axles with a full spring lift and slap it underneath there, it aint that hard.
'80 luv 4wd 6.0 vortec hurst 4spd process of lifting
'69 f-100 4wd 14" lift and 44s
'03 f-150 4dr 4wd daily
BOOMER SOONER!!!
