It is currently Tue May 19, 2026 2:39 pm
PostPosted: Thu Apr 24, 2008 1:11 pm
hi all i love my truck, but it has a four banger and not alot of horses . what can i do to pep it up with out changing the stock stuff, also what can i do about the supension and what will fit and where is a good place for parts i am in charlotte north carolina.
PostPosted: Fri May 09, 2008 1:31 pm
LUV's just dont' have a lot of ponies under the hood. It's a small pickup, give it some credit! Unless you can't hit at least 65-70mph. Maybe then there's a problem...
They're kinda hard to find parts for. Maybe a junkyard.
PostPosted: Fri May 09, 2008 2:21 pm
ret1614 is pretty much right but I would suggest you spend some time reading old posts. Use the search tool. There are a LOT of posts on this subject. There a few things you can do if you want to stray from completely stock like a weber carb, Offy intake, better distr. and so on. I'm not sure exactly how many miles mine has but I know it is well over 200K and when I get over 65 it feels like Star Trek " She can't take it anymore she's going to blow". Well it's not really that bad but you get the idea. I have a 80 4x4 and it is all stock at this point. If your state doesn't have emmisions testing you could remove the smog stuff too.
PostPosted: Wed Oct 08, 2008 9:31 am
post resurrector
I would trow all the all the stock stuff out it aint bad its just gutless. I would find a 350 or a big block for the money it aint that much more and you can get alot more horses. 8)
'80 luv 4wd 6.0 vortec hurst 4spd process of lifting
'69 f-100 4wd 14" lift and 44s
'03 f-150 4dr 4wd daily
BOOMER SOONER!!!
