It is currently Tue May 19, 2026 2:40 pm
PostPosted: Fri Feb 08, 2008 8:52 pm
Yeah, truck has been pretty good up to now. It's a 1981 4x4 4-speed manual trans gas-engined Luv. Suddenly the driver's side front wheel will barely turn. My wife watched as I tried to drive it, and said it would turn a bit and then stp, but I cannot confirm that as I was steering.
What's happening, anyone know? I don't know a great deal about how 4x4's work, so any help is greatly appreciated!!!
PostPosted: Fri Feb 08, 2008 9:28 pm
Your wheel bearing mightive seized? if the wheel engaged to the axle, and your other hub is unlocked then it shouldn't lock up, may be just the bearings
PostPosted: Fri Feb 08, 2008 10:03 pm
I would put the front end on jack stands and manually turn the wheel.
Take off the wheel and check the brake pads / rotor to see if its rubbing, then check to see if there is any slop.
Could be the wheel bearings, but I would bet on the the brakes. Maybe something got in there like sand or dirt...or your just noticing warped rotors or something along those lines....
In any case, putting the front end on jack stands and inspecting the brakes and that area in general sounds manditory.
PostPosted: Sat Feb 09, 2008 10:44 am
Hey thats funny, My 81 4x4 just did the same thing to a lesser degree.
It was my caliper. It sounds like yours may be a bit more serious.
I would recomend that you tear down the front hubs and put new parts in. I did that for my truck about 2 years ago. The chassie had more than 400k on it so it was more than about time. Oh and post some pics. We 81s need to represent!.
Gareth
81 LUV 4x4 Red Was a heavy hauler now is back to mostly stock config.
http://www.Rigeltech.com
PostPosted: Thu Mar 13, 2008 3:27 am
if your rotors worn too much and the brake pads are worn too, the piston in the brake caliper can be forced out a little too far and end up cocked sideways and seized, leaving the brakes applied. also if you havent replaced your brake fluid for a long time you can get water building up in the system. this can cause rust in the lines and in the body of the caliper. if the rust builds up enough it can cause your caliper to get seized out also.
hope this helps...
Matty
PostPosted: Thu Mar 13, 2008 9:11 pm
Sounds like you may have a frozen caliper. Could possibly have a bad brake hose??
