It is currently Fri May 22, 2026 6:07 pm
PostPosted: Sun Nov 17, 2019 10:19 am
Hello from Sacramento CA. I have a 78 luv. It was my first car. Over 300k miles. Three engine builds, 3 transmissions 5 speed swap. Dellorto carb swap, hooker header, custom cam, Impluse port fuel injection was on there for a while, 1.6 head on a G200 bottom end. All that was getting to hard to keep up and smog in CA so now it’s time for a new engine swap. 3.8l supercharged V6 from a Monte Carlo and a 5 speed from a V6 Camaro. 28 years of collecting LUV specific parts are up for sale.
PostPosted: Sun Nov 17, 2019 9:44 pm
Welcome to the site! It will be interesting to follow your future updates to your LUV!
PostPosted: Sun Nov 24, 2019 2:09 pm
Welcome! Would love to see pics.
PostPosted: Wed Nov 27, 2019 2:45 am
Welcome :ebiggrin
That would be an epic build!
Please share pics as you go along. :)
PostPosted: Tue Dec 03, 2019 10:22 pm
I will definitely post pictures
Anyone interested in a 5 speed or fuel injection setup from an impulse
PostPosted: Tue Dec 03, 2019 10:30 pm
2wd or 4x4 trans.?
PostPosted: Wed Dec 04, 2019 2:07 pm
It’s a 2wd 5 speed recently rebuilt and ready to go for a luv
With a centerforce clutch with maybe 20K on it
PostPosted: Thu Dec 05, 2019 12:17 pm
Turbo setup??
PostPosted: Thu Dec 05, 2019 7:09 pm
Would be great for a turbo but the impulse was NA.
PostPosted: Thu Dec 05, 2019 10:22 pm
Um, they came Turbo. I owned one.
https://en.wikipedia.org/wiki/Isuzu_Piazza
PostPosted: Fri Dec 06, 2019 3:57 pm
I am not saying that impulses were not available turbocharged, I am saying the intake and fuel injection system that I have for sale came off an NA impulse G200.
PostPosted: Sat Dec 07, 2019 10:50 am
What year? That makes a huge difference. The MSG-5 transmissions were all failure-prone from '81-'85. But they were MUCH stronger from '86-'89.
And how much are you asking for it? The P'up owners seem to like these, because the 5th gear ratio is higher than the other variants of this transmission (I have the '89 Impulse transmission in mine).
PostPosted: Sun Dec 08, 2019 6:52 pm
Progress to date
PostPosted: Sun Dec 08, 2019 7:07 pm
Please dont cut the core support. You can have the filler neck divorced and relocated at most any competent radiator shop. The one I did on my old truck that drummerforhire got back is in the link below...
viewtopic.php?f=33&t=28778&start=20
PostPosted: Mon Dec 09, 2019 12:00 pm
I wish photobucket didn't crap out, it would be better to see :-)
PostPosted: Mon Dec 09, 2019 12:16 pm
How can I tell what year it’s from? Once I get it out I’ll post pics on a separate thread with case numbers and such. I have been told it’s a unique transmission cause the clutch fork window is on both sides?
Nathan
PostPosted: Mon Dec 09, 2019 7:59 pm
Try one of these, then you can view them...
viewtopic.php?f=25&t=30642
PostPosted: Sun Jan 19, 2020 6:15 pm
5 speed 2wd transmission from the Luv. Anyone looking probably has 20k on the rebuild. 14246E28 is stamped on the side with 083 on the tail stock. Centerforce clutch and flywheel available as well with 20k.
PostPosted: Sun Jan 19, 2020 6:37 pm
Ok, that's a pre-'86 transmission. :(
PostPosted: Tue Jan 21, 2020 9:24 pm
What are you wanting for your transmission set up? Also what part of the country are you located?
