It is currently Mon Feb 18, 2019 6:30 am
Post new topic Reply to topic  [ 25 posts ]  Go to page Previous  1, 2
PostPosted: Fri Mar 23, 2018 8:18 am
Something came in the mail. I have already installed them but those pictures will be coming soon.
-1978 "TuFF" Luv Stepside (stock for now with a weber)
PostPosted: Fri Mar 23, 2018 7:04 pm
Great choice; good for you! Good people to work with; I purchased the setup myself several years ago.
PostPosted: Fri Mar 30, 2018 8:26 am
These brakes are sweet! Can't wait to "brake" these in. Thanks to Aerospace Components Inc. For the awesome brake kit and awesome customer support! LUVLEE is coming together slowly but surely.
PostPosted: Mon May 14, 2018 10:37 am
Long over due update.
Well the engine fits with the trans. Just need to add the trans bracket, then I can start peicing the coolant system. LUVLEE is coming together more n more.
Got a Honda radiator with fan and shroud installed. Also a small intercooler for the tiny horsepower 350hp installed. Intake manifold installed. Missing brake master cylinder until I get it bench bled. Working on centering trans mount, thanks Derrick for welding an extension. And working on clocking the turbo to make it work. Thanks Jusmx141 fixed my stripped bolt holes. More to come!
PostPosted: Tue Dec 18, 2018 3:37 pm
Another long waited update:
Shorten the rear end 8.8 to match same length on both sides, overall WMS to WMS is approx 56".
Finally rear end installed, bushings installed, brake lines fabbed and installed with brackets welded up, wheels and tires mocked up with full weight of truck. Next is to install brake master cylinder with brake fluid to check for leaks, and start mocking up fuel cell then electrical harness.
Thanks for following, Merry Christmas more to come!
