It is currently Fri Jan 18, 2019 6:16 am
 Post subject: The New Guy ...
PostPosted: Mon Sep 26, 2005 9:05 pm
I am new to the Luv, building one for the wife ... you may not like what I am doing to it .
http://www.pirate4x4.com/forum/showthread.php?t=395853
"Put on your seatbelt ... I want to try something"
PostPosted: Mon Sep 26, 2005 9:14 pm
Banishment Pending
I read your thread over on pirate, dude do it!!!!! stick the 'burb axles, engine,tranny into and onto the Luv. The Luv frame is fully boxed and is more than strong enough to handle the full size axles. Good luck and keep us posted. :twisted:
PostPosted: Mon Sep 26, 2005 10:23 pm
Sounds like a good project. I wouldn't worry about the frame. The dude who said he's seen 3 of them cracked probably didn't know what he was talking about. I've seen a few with cross members missing so it's a possibility but stock frames...I wouldn't bet on it.
Welcome to the site BTW.
Resident lurker
PostPosted: Sat Oct 01, 2005 11:17 pm
go for it. Ive never had a problem with luv frames or heard of it til now. have fun and keep us posted :wink:
http://bonsaint.com/luvalbum2/index.htm
more pics of my 76 406ci 4 spd posi.
PostPosted: Sun Feb 12, 2006 6:52 pm
This project is still going to happen. I am in the process of building a 24'x40' workshop, so that takes some time. I will be taking the engine and trans out and they will be for sale soon. The front disc assembly and the rearend will also be for sale after the shop is done.(I want to keep it a "roller")
PostPosted: Mon Feb 13, 2006 12:21 pm
Thanks for the update, I had kind of wondered what happened with your project. Keep after it, good projects always seem like a greased pig to me, just when you think you're getting a handle on it something happens and it slips out of control. :)
 Post subject: Update
PostPosted: Sun Jan 28, 2007 9:09 pm
I started stripping the luv ...
PostPosted: Sun Jan 28, 2007 10:40 pm
If it was in yellow it would look like a local guy from around heres :lol: His name is Proctor, But none the less do it. It would be bad as hell!
 Post subject: Re: The New Guy ...
PostPosted: Tue Dec 01, 2009 12:45 pm
What does it taake to bring a 72' back from the "DMV dead" (not on file) ?
PostPosted: Wed Dec 02, 2009 10:37 am
That's definitely a good thing! Just bring in the pink slip, bill of sale, or claim a lost pink slip. It's pretty easy. Being out of the books at the DMV is a good thing.
PostPosted: Wed Dec 02, 2009 10:55 am
Wait, your 4x4 thread says it's a 76. Big difference in CA, you can't get around inspections on a 76.
PostPosted: Tue May 11, 2010 2:11 pm
I found a 72 ... starting this build now.
I need some links to V8 conversion threads ...
PostPosted: Tue May 11, 2010 3:54 pm
I am in Camarillo, come look at my V-8 or V-6 conversion.
PostPosted: Thu May 13, 2010 9:41 am
Are you available Friday ?
PostPosted: Thu May 13, 2010 9:55 am
Got the registration done ...
So the plan is:
Remove the bed for now - parts of it to be reused.
Remove the front sheet metal back to the firewall.
Lift the body 4".
Remove the engine/trans/shaft.
Remove all wiring, hoses, linkage, basicly strip it.
To be a roller until the V8-700R4-208TC is mounted.
(208 is temp, will be 205/203 doubler)
And start a build thread ...
PostPosted: Thu May 13, 2010 12:31 pm
I will be here on Friday
PostPosted: Mon May 17, 2010 10:01 pm
Glad you stopped by. After you left I checked the alt as you said it was flexing when I hit the gas. Sure enough it was, the header bolts backed out causing the alt bracket to loosen up. All better now.
PostPosted: Tue Nov 14, 2017 12:11 am
Getting back to this ...
PostPosted: Tue Nov 14, 2017 1:36 pm
Blast from the past. Welcome back.
