It is currently Tue May 26, 2026 3:41 am
 Post subject: looking at a 77
PostPosted: Sat Sep 07, 2013 3:33 pm
Hi tony here
Im looking at a 77 that's a few hours away so Im trying to make up my mind before the drive. what should I look out for? are parts hard to find? will I always be wrenching on it or will they run out good?
only thing he says is wrong is the temp gauge doesn't work, is that an easy fix?
whats missing here
thanks
 Post subject: Re: looking at a 77
PostPosted: Sat Sep 07, 2013 3:50 pm
Temp sending unit. Or the wire that goes to it. Either way an easy fix. The sending unit is under the intake and has 1 wire that has a plastic connector that slips on.
They're good trucks. The carbs are troublesome. A weber is a good upgrade.
PostPosted: Sat Sep 07, 2013 4:44 pm
so that's why the temp gauge doesn't work.
whats the bracket for next to the header?
he's asking $2300
thanks for the info
PostPosted: Sat Sep 07, 2013 5:06 pm
The bracket is where the smog pump goes. If you see where the top radiator hose clamps on the thermostat, directly under that on the bottom of the intake is the temp sending unit. Ground that wire and it should raise the temp gauge to full hot. These trucks will blow head gaskets if they get hot, the gauge is important.
PostPosted: Sat Sep 07, 2013 5:32 pm
Looks pretty clean. I would look at the floor pans under the carpet or mat. If you cant do that crawl under and look for rust. It will be ugly underneath but look for holes or repairs. 8)
PostPosted: Sat Sep 07, 2013 5:58 pm
To add what LUVTRKR said, look close at the rocker panels under the doors for rust or filler.
PostPosted: Sun Sep 08, 2013 12:19 pm
was going to get it first thing this am and he text to say he sold it :cry:
found a 4x4 in alt but it was rusted bad. felony holes in floors. engine was tip top though
thanks for all the advise
PostPosted: Sun Sep 08, 2013 5:47 pm
Good luck in your search. That sucks that one got away.
