It is currently Tue Jun 16, 2026 3:23 am
PostPosted: Thu Nov 01, 2007 9:28 am
Trying to get my old 1974 Luv truck with it's stock Isuzu 1.8L 4 cyl. back together and running. This site has been a big help to me. Thank you all for your help and I will be looking foward to sharing information with you.
PostPosted: Thu Nov 01, 2007 4:34 pm
Welcome to the site. What part of Alabama are you from?
I'm currently living in Meridian, MS, just a few miles from the AL line.
1980 2wd Stock
PostPosted: Thu Nov 01, 2007 8:22 pm
Hello and welcome from another Mississippi guy...
PostPosted: Thu Nov 01, 2007 9:06 pm
Welcome :)
 Post subject: Greenville
PostPosted: Thu Nov 01, 2007 11:33 pm
I am in Greenville, AL. That is 50 miles south of Montgomery.
PostPosted: Fri Nov 09, 2007 10:19 am
Hello and welcome from up here in Washington. Luv the older Luvs, started out with a 72... :lol:
PostPosted: Fri Nov 09, 2007 11:34 am
Let me see if I have this straight.
1. Crankshaft sprocket dot to layshaft primary sprocket dot.
2. #4 piston at top dead center will be on compression.
3. Crankshaft timing pointer at top dead center mark on balancer.
4. Laysft secondary sprocket dot at 2:00 posistion.
5. camshaft sprocket dot at 6 degrees past 12:00.
6. Triangle mark on casting pointing at line mark on camshaft at 12:00.
These steps must be performed with chain slack taken up in direction of rotation which is clockwise.
7. distributor inserted with vacume advance towards rear.
8. Rotor button pointing towards engine block at #4 spark plug tower.
PostPosted: Fri Nov 09, 2007 6:51 pm
Welcome from the midwest.
Craig
