It is currently Wed Jun 24, 2026 8:35 am
 Post subject: got a diesel problem
PostPosted: Wed Mar 22, 2006 5:57 pm
My bracket that holds my power steering pump and vacuum pump worked vibrated loose and broke off bolts in the engine block. I can do with out powersteering but I gotta have vacuum for my brakes. The broken bolts will be a bitch to fix. I need a suggestion on how to get vacuum for my brakes?? The truck is a s15 gmc with a 2.2 isuzu. Old vacuum pump is on top of the motor right in front of the valve cover. I am open to any ideas....... Thanks, Bob
Excuse me while I tinker with my diesel s15.
PostPosted: Wed Mar 22, 2006 8:01 pm
First: Where do you live? so we can steal your transmission....
Second, i'm not fimiliar with the setup on a 2.2 sonoma. Unless you can grab the vac. pump and alt off of a 2.2 in a luv or pup. That'd probably work. Unless you can get a little electrical vac. pump. off of an eclipse.
PostPosted: Thu Mar 23, 2006 12:29 am
Thanks , Finalman I think my transmission is a t5 gm fairley common I think???? I bought/stole the whole 1985 s15 gmc diesel pickup for 100 bucks minus the bed and I have put 4000 miles on the baby with 0 problems till now.. Will a vacum pump off an eclipse provide vacume for my brakes?? Thats good news and what will 1 cost??? Who here has a vac. pump off a luv or a pup that I can adapt to my gmc 2.2 isuzu ? Help? Thanks, Bob
