It is currently Fri May 01, 2026 4:51 pm
 Post subject: block heater
PostPosted: Sat Nov 20, 2004 12:32 pm
where would be the best place to put a magnetic block heater on a 1981 luv diesel 4x4.
PostPosted: Mon Aug 01, 2005 7:12 pm
on the oil pan if you can because heat rises!!!!!!
 Post subject: Re: block heater
PostPosted: Mon Aug 01, 2005 8:10 pm
Honestly? From everything I've read about them, the best place would be back in the box it came out of and to the store for a refund.
I'm in several different forums, mostly diesel, and anyone who has ever posted about them for cold weather didn't like them at all, as they are too weak heat-wise to work well.
In-line coolant heaters or block heaters seem to be the best ones. I have both in my Sonoma (which has the same motor as your truck), so I can heat up quickly when needed.
Just my 2ยข. I've never tried one myself.
Bona Fide diesel fanatic.
Kubota B6100 HST diesel
PostPosted: Tue Aug 02, 2005 11:05 am
yeah thats the best option... personally if i were to go with a bolck heater i'd use a freeze plug style. they're a lot more dependable
PostPosted: Tue Aug 02, 2005 2:36 pm
Auto4life, You sound like you are experienced in block heaters, yet you live in Mesa Az.?.? 8O
I take it you have lived somewhere cold huh? :lol:
