It is currently Wed Jun 24, 2026 10:07 am
 Post subject: Custom Dual Exhaust?
PostPosted: Thu Sep 23, 2004 7:33 pm
i was wondering, if you could get a truer' v8 sound if you had a custom dual exhaust. This is the idea, the timing order of the diesel is 1324 correct? so if you made a header that put the no. 1 and 2 cyl.s into a y-pipe that ran to a flowmaster for a small gas, and then 3 and 4 cyl.s doing the same w/ 1&2 going out one side of the truck and 3&4 going the other side, shouldn't (in theory)the sound of the exhaust sound like a v8 when your on one side but when your in the cab it sounds like the reg. 4cyl. sound?
There's more to this than what i should put on here, otherwise i'd confuse the crap out of those who are here
thanks' for any opinion's on this.
