It is currently Wed Jun 10, 2026 5:34 am
 Post subject: Relay part number?
PostPosted: Fri Jun 08, 2018 5:05 pm
can anyone tell me the part number for this relay? I need to replace it but cant find the part number anywhere? its the relay in the fuse box next to all the smaller fuses.
 Post subject: Re: Relay part number?
PostPosted: Fri Jun 08, 2018 5:41 pm
Most, not all, but most, relays are pinned the same. Pull it and count the number of terminals, and a generic one should plug in, just need to be a comparable amperage between the two.
PostPosted: Fri Jun 08, 2018 10:15 pm
I don't have a parts book. I can probably see what it's called, if it's described in my shop manual.
But why do you suspect it to be bad?
