It is currently Wed Jun 24, 2026 2:27 am
PostPosted: Fri Sep 30, 2016 7:52 am
So I'm 17 and I'm looking at 82 chevy luv diesel 4x4 for my first truck but it was wrecked so he replaced the cab and bed but it's a 2wd cab and all the electrical is hooked up but none of the lights work but the dash works and fuel pump works, he started it for me and it runs fine and the body is in pretty good condition he had painted it before he put the body. I really like the truck but I want to get a good deal, what do you guys think it's worth? Thanks in advance
PostPosted: Fri Sep 30, 2016 3:04 pm
That first "sentence" was hard to read (I'm not 17). ;)
But the value of a running '82 LUV 4x4 diesel should be somewhere between $250 (low-end scrap value) and $13,000 (I saw an '81 4x4 go for this much a couple of years ago, but that it was like new). If you could post some photos, that would help to narrow it down. Based on description alone, I'd say $1,000-$2000. That's assuming it doesn't have rust. The condition of the electrical system could drag the value down, based on what you've told us. So he replaced the cab and bed, but not the chassis. Are you sure there is no chassis damage? Did you drive it? Value would also depend on the condition of the tires.
