It is currently Sat Jun 13, 2026 11:35 pm
PostPosted: Wed Mar 30, 2016 3:28 pm
Hello,
I have been looking for some 15" 6 lug wheels that will fit my 82 luv so I can get away from a 14" tire but so far everything I have located has been out of my price range.
I have a 1993 chevy S-10 that has 15" tires but it has 5 lug wheels. What I was thinking about doing was swapping the wheels to my Luv ?
I know the front spindle's would have to be changed but I am not sure what to do with the rear end. I wonder if I could swap axle's ? If not axle's then the whole rear end would have to be swapped out.
Now that I have put my idea on paper it looks like a LOT of work for something as simple as a wheel upgrade !! Ha, Ha Maybe I should just keep looking for a better price on a 6 lug 15" Toyota or Nissan wheel............ ?????
Any ideas ?
PostPosted: Wed Mar 30, 2016 3:49 pm
hunter62 wrote:
Maybe I should just keep looking for a better price on a 6 lug 15" Toyota or Nissan wheel............ ??????
Yep. I think the bolt pattern is the same as for GM 6-bolt wheels (6x139.7mm), but the center hole is generally the issue. If I recall correctly, you'll need a 108mm center hole (just a hair larger than 4.25 inches).
