It is currently Thu Mar 28, 2024 10:40 am
PostPosted: Fri Feb 27, 2015 8:19 pm
Hi there! I have an all stock 1979 Chevy Luv 4x4 that I am putting a 3 inch body lift on. I want to put the biggest BFG All Terrain tires on it as possible without cutting the fenders. My question is what is the biggest tire that will fit on an all stock luv with a 3 inch body lift kit and UNCUT fenders? Any help is GREATLY appreciated Thank you!
PostPosted: Thu May 28, 2015 9:50 pm
I would assume if you have wheels that dont stick out of the fenders, then you would maybe be able to run 31's. I have 31" tires on mine with a 3 inch body lift and the front tires stick out probably 1 1/2" - 2" and i had to cut the fenders a little bit in the back, doesnt look too bad and pound in some metal inside the fender a bit too. I also turned my torsion bars up a bit too. if you dont want to modify anything at all, i'd say go with 29's or maybe 30's
1980 4x4 LUV, 3 inch body lift, 4.56 gears, 31x12.50r15 Super Swamper IROKs, Weber Carb, Electronic distributor,
PostPosted: Thu May 28, 2015 9:52 pm
even with the stuff I did, the sometimes hit if I'm haulin ass and hit a bumper while the tire is turned.
