It is currently Thu Apr 18, 2024 6:26 pm
 Post subject: Thermal switch
PostPosted: Fri Dec 16, 2011 9:23 pm
What does the thermal switch on an 82 diesel LUV engine do? Mine has the wire(s) broken off, can it be replaced or fixed?
 Post subject: Re: Thermal switch
PostPosted: Sat Dec 17, 2011 12:45 am
Australian LUV Guru
It shortens the glow cycle when the engine coolant is above a certain temp, the resin can be dug out around the wires and re-soldered on.
1980 4x4 KBD40 ISUZU/Chev Luv
PostPosted: Sat Dec 17, 2011 9:20 am
There are two. The other one is for fast idle.
Oz is exactly right. If the wires are broken, you get a full glow cycle whether you need it or not. And I used a Dremel do just as he said to repair mine.
PostPosted: Sun Dec 18, 2011 2:56 pm
thanks guys! I'll borrow the wife's old dremel and get er done :P
