It is currently Wed Jun 10, 2026 3:06 pm
PostPosted: Mon Sep 27, 2010 3:42 am
I WAS WONDERING IF ANY ONE KNOWS WHAT THE VALVE LASH ON IT
IT HAS A CROSS FLOW HEAD ON IT. MEANING INTAKE ON ONE SIDE AND EXHAUST ON THE OTHER SIDE OK SO I DONT KNOW WHAT YEAR THE ENGINE IS BUT WOULD LIKE THE HELP ON THAT OK THANKS
DAVE
PostPosted: Tue Sep 28, 2010 9:25 pm
If its a 2.2 it is .16 on intake and the same for the exhaust.
Larry
82 Isuzu Long Bed Diesel
PostPosted: Wed Sep 29, 2010 2:52 am
OK BUT CAN U TELL ME WHERE THE NUMBERS ON THE BLOCK IS SO I CAN SEE WHAT YEAR AND KIND OF ENGINE IS OK THANKS
PostPosted: Wed Sep 29, 2010 3:49 am
Australian LUV Guru
Left side of engine block should have large raised lettering C223
1980 4x4 KBD40 ISUZU/Chev Luv
PostPosted: Fri Oct 01, 2010 12:00 am
what country are you in??
the USA did not get a diesel tell 81, and we only got the C223 and none of the others.
it Cinda sounds like you have a older C190 engine, and your out side the usa.
86trooperT/D 2.2
84 L\B 4x4Diesel LS 2.2
86 L\B 4X4 gas 5 speed 2.3
PostPosted: Fri Oct 08, 2010 12:56 am
YES I KNOW THAT BUT I GOT THE TRUCK THAT WAY. SOME ONE ELSE PUT IN THE DIESEL IN IT. AND I FOUND THE NUMBERS ON BLOCK IS 4FB1. FOUND OUT THAT IS A 1.8L OK. NOW I AM THINKING OF LOOKING FOR A 86 OR SO TROPER II FOR THE 2.2 TURBO THAT CAME IN IT LOL THANKS
PostPosted: Fri Oct 08, 2010 1:19 am
UNLESS ANY NEWER DI TURBO DIESELS THAT CAN PUT IN ITS PLACE????? HAS ANY ONE DONE THIS KIND OR ENGINE SWAP YET??? MAYBE SHOULD TRY TO FIT A DURA MAX IN THERE.
PostPosted: Fri Oct 08, 2010 7:36 am
Isuzu sold a 4JB1-T overseas that produced over twice the HP of your 4FB1, and loads more torque. It's supposed to be a great engine. It can fit into a P'up with some body lift (2"). It will probably fit the same mounts, but I don't know about space in the engine bay. These usually come with a 5-speed 4wd transmission still attached and are available from several Japanese Domestic Market ("JDM") importers and often listed on eBay. Some of the IsuzuPup.com members have them. It would turn your LUV into a real beast.
PostPosted: Sat Oct 09, 2010 6:45 pm
OK I LOOK IN TO IT. I WAS ALSO THINKING MAYBE A 4BT CUMMINS OR SEE IF CAT HAS A BABY 4 CLY ONE TOO LOL
PostPosted: Fri Dec 24, 2010 12:50 am
A 4bt Cummins swap in a luv, would not be easy to do, There are only so many trans you can use and What you dont think about is that The Clutch, Most of them are Hyd clutchs, And you have to cut out your inner fender to get the ford or the dodge clutch cyl to fit, and Unless you plan on goin to straight axle then the 4bt weight will never fit with the luv front end, A 4bt weights about 700 pounds, the little 1.9 luv motor is like a 1/4 the weight of that. Haha Just some thot
PostPosted: Fri Dec 24, 2010 10:34 pm
WOW IF I AM GONA DO ALL THAT THEN SHOULD JUST DROP BIG BLOCK AND REALLY HAVE SOME FUN THEN LOL. I FOUND OUT THAT THE 86 TO 89 TROOPERS HAD A 2.2 TURBO DIESEL THAT SHOULD BOLT UP TO MY TRANS AND STILL USE EVERYTHING I HAVE NOW
PostPosted: Fri Dec 24, 2010 10:38 pm
THANK YOU FOR THE ADVISE. BUT I MISS MY LUV BECAUSE THE CLUTCH JUST WENT OUT IN IT 4 DAYS AGO :( :P :lol:
PostPosted: Sat Dec 25, 2010 2:32 pm
Haha Yea i didnt want to come off the wrong way, it could be done with a will and a way, but in the normal luv frame that would be alot of work, You would just have to rebuild the luv frame to take the weight. I thot about doing it, but i but the ranger frame to put my cab on so maybe the cummins will come later sence now my front inned of the ranger can take the weight of the 4bt now, haha An ive had to mount all the clutch hy, and the brakes and all that good stuff to mount the luv cab just to the ranger frame, so haha maybe a cummins in the works in mine! haha Heres a pic of it, i think it looks Sweet! haha
PostPosted: Mon Dec 27, 2010 12:40 am
WOW LOOKS GREAT MAN
PostPosted: Mon Dec 27, 2010 2:05 pm
Haha Yea i really like it! Way different look haha :D
PostPosted: Mon Dec 27, 2010 11:30 pm
IF I CAN GET SOME PICS OF MY LUV U LIKE IT SOME ONE DID THE 2 OR 3 INCH BODY LIFT AND SOME BFGS ON IT HAS FIBERGLASS FRONT FENDERS AND OLD SCHOOL PRE RUNNER BUMPERS FRONT AND REAR ON IT
PostPosted: Thu Dec 30, 2010 8:09 pm
Haha That sounds Cool! Yea GET SOME PIC!!! haha :D
PostPosted: Sat Apr 16, 2011 12:46 am
Guess what i found out that dmax makes a v6 3.0l diesel. I am tring to find out more about it and if it is availble :P
PostPosted: Sat Apr 16, 2011 8:15 am
It's computer controlled, so you will need a lot more than just the engine.
PostPosted: Sat Apr 16, 2011 5:38 pm
I KNOW I WAS GONA SEE WHAT THEY CAME IN AND SEE IF I CAN FIND ONE IN A JUNK YARD WITH THE HARNESS AND CPU :p I FERGOT TO MENTION THAT IS ALSO TURBO AND INTERCOOLED TOO
