It is currently Tue Jun 09, 2026 1:42 am
PostPosted: Mon Sep 06, 2010 2:02 pm
'81 LUV Diesel.
I replaced the Fuel Filter Assembly with one that does not have a Bleed Screw.
How do you bleed the Air out ???
I looked at my old one and the Bleed Screw is on the Inlet Side of the filter. I pumped and pumped (like bleeding brakes) and loosed the inlet and then outlet but NO Fuel and NO Air Visible or Leaked ????.
Pump Ball seems hard now .
All Fuel lines are tight
Thanks for any help !!!
PostPosted: Tue Sep 07, 2010 6:41 pm
Well .... if you have not started it yet, just fill the filter with fuel and go to town. If you have started and ran out of fuel it is a little more difficult. The plunger will have to be operated while cracking the incoming line to the pump then out to injectors one at a time ect.
82 C 223 250K. Runs as new except the crap transmission.
PostPosted: Tue Sep 07, 2010 10:07 pm
Search around on this site. Might be more help for you. http://www.isuzupup.com/
PostPosted: Wed Sep 08, 2010 8:11 am
Thanks for the information!
