It is currently Sun Apr 28, 2024 10:05 am
 Post subject: 6.2 turbo diesel?
PostPosted: Thu Feb 26, 2009 12:35 pm
Has anyone on here but one of these in or similar size diesel?
I know where I can get one for the price it would cost to fix my stock 1.8L gas motor, and have been thinking of switching over to diesel.
2003 F250 7.3L
1975 Luv
 Post subject: Re: 6.2 turbo diesel?
PostPosted: Thu Feb 26, 2009 3:11 pm
The 6.2 and 6.5 in my opinion were the worst engine made. I used to work as a mechanic for a place that had more of these then anyone else in the U.S. I will say this, I would use the 6.2 as a boat anchor but it might fail at that also.
PostPosted: Thu Feb 26, 2009 4:35 pm
na the GM 4.3 5.7 diesels are by far worse :!:
the 6.2 with the newer B head setup does ok if (no) turbo.
turbo a 6.2L and you have a ((very high)) risk setup. even in a little LUV or pup.
though 130HP in a little LUV with 250+tourqe getting the same mpg as the 1.8 gaser woudent be that bad.
if the frame and aixels can handel it.
if your guna go thru the trubble of beffing the frame and aixels the cummens 3.9 I-4 would be a better way to go. though more $$$$$$ to do. but LBs 550ish for the 3.9 i think its a little less LBs than a 6.2L or 6.5L engine.
it can be done ether way but its a big project.
one of thoese inported 2.8 3.1 isuzu diesels would be a much esear install, no body lift. though $3,000ish for the engine trans and there all 4x4 that i have seen. same power as a 6.2 from a 2.8 or 3.1 engine stock. :P
86trooperT/D 2.2
84 L\B 4x4Diesel LS 2.2
86 L\B 4X4 gas 5 speed 2.3
PostPosted: Sat Feb 28, 2009 12:11 pm
what disels in chevys 3500 with the allison 6.6 i think i heread there awsome and theres one in my boss's service truck with wieghs 12,000 pounds and i was in the ford f250 with the diesel motor tubrbo also and i couldnt for the life of me keep up with him he also says he raced a doge and won too
75-luv mikado-V8 350 soon
PostPosted: Sat Feb 28, 2009 12:54 pm
all the ford 7.3 make less than 225hp tell around 96 or 97. even the power stroke that came out in 1994-1\2.
that 6.6 isuzu\GM engine is over 300hp or more 8O :D
and an extra 200+ or so of touqe 600 rpms lower.
86trooperT/D 2.2
PostPosted: Sun Mar 01, 2009 12:15 am
This is all fine and dandy, but you must consider this engine weights a LOT more than the original engine. The front end won't be designed to handle so much weight without major reconstruction.
But that's just my 2c worth. :egeek
Bona Fide diesel fanatic.
Kubota B6100 HST diesel
PostPosted: Mon Mar 02, 2009 10:51 am
Thanks for all your input I am not going to go that route.
2003 F250 7.3L
1975 Luv
PostPosted: Sat Mar 14, 2009 9:03 pm
Yes, stay the F*** away from 6.2L and 6.5L GM diesel engines. They are ticking time bombs (my neighbor is trying to sell his 6.5L suburban, and I saw the mess under the hood one day....turbocharger is slinging oil badly and it runs like s*** when he first starts it!)
