It is currently Wed Jun 24, 2026 10:08 am
PostPosted: Wed Sep 17, 2008 11:22 am
I have a 82 chevy silverado diesel and the glow plugs are not coming on and the engine cranks over but does not start. I don't know much about diesels and I am guessing I need my glow plugs to start the engine. Can I run a hot wire from the glow plugs to a switch in the cab or something along those lines.
Thanks
Cody
PostPosted: Wed Sep 17, 2008 7:55 pm
Make sure the glowplugs are rated for 12 volts before putting full voltage to them. I understand a lot of glowplugs are only rated at 5 volts.
If you put full voltage to the glow plugs, apply the voltage for no more than 5 seconds and see what happens.
Hope this helps.
PostPosted: Wed Sep 17, 2008 8:35 pm
Thank you for the help!
PostPosted: Thu Sep 18, 2008 4:14 pm
Let us know how it goes if you try that, will you?
