It is currently Wed Jun 24, 2026 2:14 pm
PostPosted: Wed Apr 16, 2008 11:04 pm
Hello to all. I am wanting to change the fluid in my diff. i think i have found the drain plug at the bottom but my question is where do i add it back. Is it the small tube 1/4in round on top. Ok well second question is the same but for the tranny. It is a 5 speed manual bolted up to the diesel engine and i can t find anywhere to add fluid back if i drain it or even a dip stick to check it. thanks for the help. :D
PostPosted: Thu Apr 17, 2008 11:07 am
Just changed the fluid in my tranny. It has a plug on the bottom and one near the top on the drivers side. No dipstick to my knowledge. Just fill it up till a little comes out the top hole. I used a gear lube bottle and a hose to get it up there.
The manual recommends 30w motor oil, or 5w30 for the tranny, not sure on the rear end.
Hope this helps.
Dbear
'82 Chevy Luv Diesel - Nicknamed "Thunderdome" by my wife
PostPosted: Sun Apr 20, 2008 11:43 pm
thanks for the help you guys are awesome.
