It is currently Thu Jun 25, 2026 2:13 am
 Post subject: lubricants
PostPosted: Sat Mar 29, 2008 6:08 pm
I have an 81 luv truck with a diesel and a 5 speed tranny in it. 2wd. does anyone have any suggestions for what type weight etc... lubricants to use for the 1. differential 2. tranny 3. engine oil 4. grease certs. 5. fuel filter . the truck has been sitting for some time now but still runs really well. i am about to start using it fairly often and just wanted to give it a lubricant tune up. and if anyone has any suggestions as far as things to do or check into for this situation before driving it regularly that would be great! thanks for the help!!!!! :D
 Post subject: Re: lubricants
PostPosted: Tue Apr 01, 2008 7:17 am
For the transmission, 5w30 motor oil. Back in 1981, I think the recommendation was straight 30-weight motor oil, but Isuzu later revised that. I'll have to check my manual for the other lubricants. The fuel filters are available at places like Autozone, and they're around $20. You may want to take a look at the Isuzu P'up forum as well as this one -- http://www.isuzupup.com.
PostPosted: Tue Apr 01, 2008 10:03 pm
LUVTruck.com's Cornholio
i use 75W-90 in the rearend and Delo 400, 15W-40, in the engine.
