It is currently Wed Jun 24, 2026 5:37 am
 Post subject: Rev her up!
PostPosted: Mon Feb 11, 2008 12:06 pm
What kind of a setup does one need to install a Tach to work with a 2.2L Diesel?
Regards,
Bob
 Post subject: Re: Rev her up!
PostPosted: Mon Feb 11, 2008 3:31 pm
If you have a "W" terminal on the back of your alternator, you can use the "Universal Diesel Alternator Tachometer Interface" from Dakota Digital to connect any standard ignition tachometer.
http://www.dakotadigital.com/index.cfm/ ... prd128.htm
PostPosted: Tue Feb 12, 2008 9:10 pm
You still need the W terminal, but for me I used a marine Diesel tach for a boat, installed it in a 3" abs coupler, and mounted it on my a pillar. Only counts to 4000rpm, which is fine for me as the engine only revs to 4200 anyway, and yo get a good sweep with this one.
Bona Fide diesel fanatic.
Kubota B6100 HST diesel
PostPosted: Wed Feb 13, 2008 6:35 pm
Thanks, I will look into this and let you know what I found out. Wow, that interface is 65 bucks.
Regards,
Bob
PostPosted: Sat Feb 16, 2008 1:24 am
AutoMeter makes one for small diesel's; 5k rpm; sensor gets signal from the altenator. That is....sensor straps around the altenator with supplied stainless steel hose clamp.
----Pat
1982 Isuzu P'up Diesel LB ---QRP---Daily Driver
1997 Ford F-250 SC 4x4 TurboDiesel PowerStroke --QRO--- Tow Vehicle
1993 Davis W/A saltwater fishing boat
PostPosted: Sat Feb 16, 2008 1:15 pm
CabezonBD, thanks and I really like where yours is mounted. Would you have a model #?
Regards,
Bob
PostPosted: Sat Feb 16, 2008 1:39 pm
Here is the info below. Autometer also has the installation instructions for download on its site if you want to see whats involved. I shopped and this was the bestprice I found on line at the time.
BTW, Where I istalled it, the ring of the mount needs to be "bent/twisted" so it's more in line with a better view to the drivers view. If this doesnt make sense, it will if you install it in the same place.
Shipping Method: FREE Super Saver Shipping
Shipping Preference: Group my items into as few shipments as possible
Subtotal of Items: $112.88
Shipping & Handling: $5.58
Super Saver Discount -$5.58
Total for this Order: $112.88
Shipping estimate for these items: January 21, 2008 - January 22, 2008 1 "Auto Meter 3788 Silver Pedestal Mount Mini-Diesel / Sport-Compact Tachometer Gauge"
Misc.; $112.88
Sold by: Amazon.com
----Pat
PostPosted: Sat Feb 16, 2008 1:48 pm
CabezonBD, perfect, thanks. I have been searching their site all this time but all I needed was that number and it is all clear now, I like it. Thanks again for your time.
Regards,
Bob
PostPosted: Sun May 04, 2008 1:05 am
or a diesel Tiny Tach
http://www.tinytach.com/tinytach/diesel.php
'82 Luv diesel 5spd - 270k miles - recently purchased from neighbor
planning wvo conversion
UNIX SA in real life - diesel head otherwise
