 Post subject: A/C question
PostPosted: Wed Aug 22, 2007 9:54 am
I want to convert my A/C system in my 82 LUV to R-134. I found one port on the accumulator (I think that's what that is) near the driver's side headlight. Now, the dumb question: Does anyone know where the other port is? I believe it's the low pressure port?
PostPosted: Wed Aug 22, 2007 5:15 pm
On my 80, it is right at the back of the compressor.
PostPosted: Thu Aug 23, 2007 5:40 am
Hmm... I've looked there. Nothing but hose going to the compressor. Is it under the flange/block on the compressor?
PostPosted: Thu Aug 23, 2007 5:11 pm
On the curved metal tube coming out of the back of the compressor. Should have a metal valve cap on it. It's vertical and you'll be looking straight down on it. And yes. It's the low pressure side.
PostPosted: Tue Aug 28, 2007 10:50 am
Found it. It's on the back of the compressor (literally) I was looking for it to be inline on a hose. I initially thought it was a bolt. Thanks for your help! :D
PostPosted: Mon Sep 03, 2007 6:39 pm
If this is the low pressure / suction side of the system make sure to charge it with vapor as there is nothing to prevent valve damage to the compressor from liquid charging .
PostPosted: Tue Sep 04, 2007 2:48 pm
10-4, roger! :D
