 Post subject: Lift pump
PostPosted: Tue May 29, 2007 10:37 am
I know I'm going to get burned for this, but what is a lift pump and where is it located on my 82 LUV? Let the flaming begin...
PostPosted: Tue May 29, 2007 10:44 am
Gas or diesel? Why would you be flamed asking a honest question?
PostPosted: Tue May 29, 2007 1:22 pm
Diesel. I've never heard of this until I got this truck. I figured a pretty basic question would get a lot of ribbing. :lol:
PostPosted: Tue May 29, 2007 4:18 pm
Basically the lift pump does just that, it lifts the fuel out of the tank and delivers it to the injection where the injection pump takes the high volume/low pressure fuel from the lift pump ans converts it to high pressure lower volume and times it for the cylinders.
That is the quick answer, hope it helps
PostPosted: Tue May 29, 2007 4:44 pm
Think of it as a primer pump for the injector pump.As injector pumps are more efficient when pre charged with a lift pump.
PostPosted: Wed May 30, 2007 5:50 am
Gotcha. So is it in the tank or externally mounted?
PostPosted: Wed May 30, 2007 9:02 am
good ? ... i have never heard of it either... and now we both know
PostPosted: Wed May 30, 2007 12:51 pm
Neither. There is no lift pump on stock '81-'87 diesel LUV/P'up trucks. It's not normally needed if the injection pump is working properly, and you're burning regular diesel fuel.
If your '82 has one, it's aftermarket. If you can't find it, it's probably not there.
PostPosted: Wed May 30, 2007 3:45 pm
Ahhhh....thank you oh wise one! I was trying to work on all the variables for my conversion to WVO, and this was one of them. Kewl...now on to other things... :smt066
PostPosted: Thu Sep 13, 2007 9:17 pm
LUVTruck.com's Cornholio
so is it a good idea to have a transfer pump with these engines? I was thinkin of using a little electric one that i have on my gas engine.
PostPosted: Sat Nov 10, 2007 2:27 pm
No, I wouldn't advise running a seperate transfer pump/lift pump on a diesel vehicle because the engine's fuel injection pump already has a built-in lift pump. It is how the C223 diesel is set up and how most other diesels are too. It's the beauty of owning a diesel too, as having a fuel pump designed to deliver fuel to the engine is mainly just needed for gasoline vehicles. And some gassers have the fuel pump in the fuel tank, what a pain! As long as your diesel engine is running fine on diesel fuel there is no need to mount an individual electric pump to aid the injection pump. The factory never used one, why put one on now.
Salvy
1982 Chevy LUV diesel
2.25" stainless exhaust
w/ MagnaFlow performance muffler
PostPosted: Sat Nov 10, 2007 2:43 pm
well on the swap I left it there. Its been on there for over two months and it runs and drives just fine. dont have to prime it either.
