PostPosted: Sun May 20, 2007 12:27 am
Australian LUV Guru
Ok got a alt with internal regulater, what do i do with 3 wires in plug and the 1 thick wire that was used with old stock alt :?:
1980 4x4 KBD40 ISUZU/Chev Luv
PostPosted: Sun May 20, 2007 7:31 am
Yours is Diesel is it not????
What are you going to do for a vacuum pump???
PostPosted: Sun May 20, 2007 9:06 pm
Australian LUV Guru
New alt is of a diesel, has v pump on back. Should have mentioned that. :roll:
PostPosted: Mon May 21, 2007 7:11 am
Go in the Ozgemini forum and look in the tech section. There should be an article in the workshop section on how to wire it up.
Actually i think theres more than one thread on the alternator itself have a look around. I cant remember if the info is in the thread i posted about the bracket mod.
The Luv uses the same reg as a Gemini-earlyJackaroo and G-series Rodeo.
Cheers, Bob.
PostPosted: Mon May 21, 2007 9:52 pm
Australian LUV Guru
Yeah pulled a reg outer a Gemini awhile back, was a electronic style. No more old relay type, fixed the prob with the headlights diming at idle.
