It is currently Wed Jun 24, 2026 5:37 am
PostPosted: Sat May 19, 2007 8:47 pm
Australian LUV Guru
I wish to fit a larger amp alt but unsure what to do about vaccum pump bolted to rear of original alt. :?
PostPosted: Sat May 19, 2007 9:53 pm
Do you have a good starter/alt. rebuilder you can go to? They should be able to rebuild yours and up grade the the fields to get more amps.
PostPosted: Sun May 20, 2007 7:32 am
Best be would be an alternator off a different diesel.
Patrol or landcruiser or similar large 4x4.
You will have to fab up some brackets for it.
Bob.
