PapaG wrote:
Got it back from where:? Was it running . I don't know much about the Luv- Trooper-s10 diesels. be careful as diesel injection pumps can put out as much as 30,000 psi or more. Not these but it could be 3000 to 5000. I also do not know if the they use a lift pump(a pump between the fuel tank and your IP) but if it does it may be bad.
Check your fuel filter. It should be before the IP. HTats where I would start first. If no lift pump the Injection pump must have a fuel pump built in, like a Staydine pump. If it sat up it could be most anything. The filter is where you need to start If it is the IP you can get it rebuilt in most larger cities, get a rebuilt or exchange, also a used pump.
I know a lot about other diesels, and their are a lot of simular setups.
Olds 5.7, GM 6.2, 6.5 Cummins 3.9 and 5.9. VW Diesels. Big Cat, Detroit, Cummins, Internationals and more.
Let us know what you find. I bet it is the fuel filter...
RIchard
Richard
That's what i was thinking, probably clogged to hell. And no they don't have lift pumps.
-Curr. rides- 1970 Ford LTD 4dr, 390 4Bbl, 2nd owner! With a few Extras
00' Civic beater...
