It is currently Wed Jun 24, 2026 5:37 am
 Post subject: Sea Foam
PostPosted: Tue Jul 04, 2006 5:33 am
I added Sea Foam to my diesel fuel. I was told it would help clean the injectors and whatnot. All I've noticed is my truck runs quieter but I think it seems to have lost power. Has this happened to anyone before?
PostPosted: Tue Jul 04, 2006 9:30 am
did it loose power while sea foam was in the tank, or a couple of tanks later??? That's probably all the problem was, when i ran a kerosene to diesel mix in my truck (bout 30K/70D) It ran alot quieter but with less power, b/c kerosene ignites before diesel does so that little bit of power you could've gotten from it wasn't used, but it did clean out your cylinders and your injectors... got better milage out of it with a couple of tanks of the concoction.
PostPosted: Tue Jul 04, 2006 10:18 am
I noticed right after I put it in the tank. I'm still on the same tank so I guess I'll see if everything returns to normal when I fuel up again. Thanks
