It is currently Wed Jun 24, 2026 5:37 am
PostPosted: Fri May 19, 2006 9:22 pm
Hey guys. Due to alot of corrosion in the cooling system, the housing for the thermostat has died in the ass.
It all started when i tried to undo a bolt to remove the thermostat. Snapped the bold.
Drilled it out.
Snapped a drill bit when almost finished drilling out.
Tapped drill bit out with nail punch.
Whole thermostat housing snapped off the block.
In some parts the cast alloy was 1mm thin or less and other parts it was still about 10mm thick.
So yeah i need the entire part you see below. Need the top part that has the 2 sensors in it and also need the bottom part that has the 1 sensor and yellow wire going into it..
My ute is a 1980 2L diesel 2 wheel drive.
Willing to ship over from the USA becasue these parts are not available over here.
Cheers.
