It is currently Thu Apr 18, 2024 9:24 pm
 Post subject: In Need of a Banjo Bolt
PostPosted: Wed Nov 15, 2017 9:01 am
Messing with my '81 diesel I ended up breaking off a banjo bolt from the fuel injection line. Any idea of where to get one?
PostPosted: Wed Nov 15, 2017 10:25 pm
Which one is broken? Is it the one on the pump? I may have one.
PostPosted: Thu Nov 16, 2017 10:54 pm
its one of the four that attaches the fuel rail to the injectors, I need two if you have them
PostPosted: Thu Nov 16, 2017 11:00 pm
Sorry, but I’m not familiar with a fuel rail in this system. Are you referring to the steel return line that connects to each injector?
PostPosted: Sun Nov 19, 2017 11:11 pm
Yes most likely, I am not terribly mechanical.
PostPosted: Mon Nov 20, 2017 12:34 am
I doubt I have those, but I'll check. You should contact Dart and Deb Eskew (sqdeb@yahoo.com). Let us know if they don't have them. I'm pretty sure we can track some down.
PostPosted: Wed Dec 06, 2017 7:30 am
I see you haven’t been back here since November 20. Did you find the banjo bolts? I have one for the pump, but not for individual injectors.
PostPosted: Wed Dec 06, 2017 7:31 am
JoeIsuzu yes I found some, thank you anyway!
