It is currently Wed Jun 24, 2026 4:11 am
PostPosted: Tue Feb 05, 2008 9:41 pm
and how much and where could i possibly get one? just curious as im thinking of converting my luv...
do you believe in LUV at first sight or does one have to drive by you again?
76' stepside mikado w/sunroof
PostPosted: Tue Feb 05, 2008 10:57 pm
LUVTruck.com's Cornholio
as far as putting a diesel with the tranny into a luv?? Change the yoke on the drive line and raidator.. Easy enough.. Just get all the wires for the glowplug system and its a direct bolt in.
PostPosted: Thu Feb 07, 2008 9:36 pm
any idea how much a conversion would cost?
PostPosted: Thu Feb 07, 2008 9:46 pm
well besides the cost of the donor truck? Not very much. I used a lot of the same things.. But it did change the oil on the engine and tranny. New Anti freeze. A couple new hoses. I put a new clutch in while it was out too. I would guess $150 total extra after the donor truck.
PostPosted: Sun Feb 10, 2008 5:31 pm
Hows the power compared to the gas motor?
1975 V8 Luv
1980 Bagged Luv
PostPosted: Mon Feb 11, 2008 9:04 pm
well FarmerJoe drove my truck when he had his luv. mine with stock N/A diesel and his with the G180 (with header/exhaust, and weber carb.) and he claimed that it seems to be the same. I think its close too maybe better because of the torque.
 Post subject: Re:
PostPosted: Tue Feb 12, 2008 12:57 am
Hey Pee_roy, what year is your luv? I have a '75 that I'm going to put the 2.2l diesel in but I'm pretty sure the motor mounts are different. I'm guessing it's because of the engine change in '76.
My build thread.
PostPosted: Tue Feb 12, 2008 8:19 am
Its a 77. I dont know about the earlier models.. Oh and that reminded me, you need the original tranny mount. the spacing were the bolts go through on the crossmember is wider on the diesel truck. Easy just a matter of changing them.
PostPosted: Sun Mar 23, 2008 7:37 am
My 81, from the limited 5 minutes I've driven it, was a lot easier to move than my 80 gas 4x4. I think it has to be the extra torque the engine makes.
1981 Chevrolet Luv - Diesel - 86 P'up Transmission - IT RUNS
1980 Chevrolet Luv - Gas - 4x4 - Sold then wrecked
1980 Chevrolet Luv - Gas - 4x4 - Rusty parts truck
1999 Ford Taurus SHO - 32V 3.4L V8 - Borla SS mufflers
1970 Honda CL350K2 - Candy Blue
