It is currently Mon Jun 15, 2026 11:13 am
 Post subject: A new home for the LUV
PostPosted: Wed Sep 30, 2015 4:11 pm
I haven't been around much the last couple of years as a lot of things have been going on. But finally getting settled into our new home, got some land, and finally got the new shop built. Hopefully now I can finally get around to getting the LUV back up and running.
PostPosted: Wed Sep 30, 2015 10:52 pm
Awesome work shop !
PostPosted: Wed Sep 30, 2015 11:19 pm
Very cool 8)
PostPosted: Mon Oct 05, 2015 5:04 pm
I retired almost two years ago and moved from CT to Florida. I had way too much stuff and had to build a garage to hold it all. 24 X 28 and it is too small! I got the Luv fired up, it took two weeks to get it going but I swapped the front drum brakes for disc brakes and also had to epoxy coat the gas tank. I put the truck on a trailer and drove 1100 miles to get it to Florida. The truck has sat since but I plan to make it a driver once again. 327 with TH350 and narrowed 12 bolt Chevy rear.
Believe me I know what you are going through! Thanks for the pictures!
