It is currently Sat Jun 13, 2026 1:24 am
PostPosted: Thu Nov 20, 2003 8:11 pm
would the magnets from a set of 4" component speakers have any adverse effects on a tape deck or a cassette tape (ie...erase the tape) if there is a piece of 1/2" plywood separating them?
PostPosted: Thu Nov 20, 2003 8:49 pm
it's possible. If there's only a half inch of space between a magnet and magnetic media, then it wouldn't matter if there was plywood in between or not. You could probably get by with about 12" of space in between them.
I would hold a speaker somewhere near a tv and note when the image distorts. Keep the speakers at least that far from your cassettes.
PostPosted: Thu Nov 20, 2003 9:25 pm
hmmmmm.....ok im trying to keep it as small as possible.
i wonder if i could use something to insulate like maybe thick rubber?
heres what im trying to pull off. when i deploy i will be driving a peice of shit army truck (2 1/2 ton cargo) for a VERY long time. and guess what? army trucks dont gots radios in the past ive used boom boxes and such. but i wanna get something i can wire up to one side of the 24volt system on the truck.
so i am building a box that will hold the HU and a speaker basicaly.
and before ya say use a CD player......tapes are much more durable and i think the truck will vibrate too much to use the CD player w/o it skipping like crazy.
PostPosted: Fri Nov 21, 2003 12:10 am
Hey Larp ...when i was in the service ...Many Moons ago we used coper to make a radio work in our duce&1/2s'...do they still have dues'es.....? If ya need a good barrier for a raido make ya a thin sheet of coper covering.......and ya should be good to go SOLDIER!.....By the way the wax worked good for my headbolt extraction...Thanks 8)
PostPosted: Fri Nov 21, 2003 5:16 pm
if you want to use rubber, just find someone you really hate and cut a 1'x1' hunk out of their tire and leave. or you could find an old tire and cut off the tread.
PostPosted: Sun Nov 23, 2003 1:40 pm
well i ended up gettin pissed cuase i could'nt find any thing so i just put the rasio on the oppsite end of the box. there is about 9" between them.
and John. yep we still got dueces. i get to drive my POS to the mob station. its a welding truck setup and old and worn out. top speed is 40mph......period :evil:
hopefully i will get to trade it in for a new FMTV :D ........if not, and i got to drag that POS to the desert im gonna find me a bored combat engineer with a couple pounds of C4 :twisted:
