It is currently Sat Jun 13, 2026 1:24 am
 Post subject: got new truck
PostPosted: Sun Nov 09, 2003 5:23 pm
ok I traded a 1986 ford t-bird turbo coupe for a 1987 C10 chevy. The truck needs a V-8 transplant that will happen this week then I can tear down the Luv engine again to fix piston booboo. nope not to much GAS just way to much timing ( the dist was loose and advanced way to far ) the piston really didnt like that very much.. kinda cracked it in the wrist pin. Oh well so it goes.
GOTTA GET A NEW LUV!!!!!!!!!
