It is currently Sun Jun 14, 2026 2:22 am
Post new topic Reply to topic  [ 33 posts ]  Go to page 1, 2  Next
 Post subject: 350
PostPosted: Tue Jan 22, 2013 11:10 am
So I have been looking around and price checking everything and I've come up with this, a 350 made into a 327, a turbo 400, and an 88 Isuzu trooper rear end. Sound successful? Tell me what ya think before I get in to deep. I am a budget builder so keep that in mind. 78 chevy luv bone stock btw.
I Dont Need Sex Life Fucks Me Whenever It Can.
 Post subject: Re: 350
PostPosted: Tue Jan 22, 2013 12:38 pm
I Vote keep the 350 a 350...
PostPosted: Tue Jan 22, 2013 2:15 pm
Vote #2 for 350 . Also 400 is bigger and harder to fit into the truck . I suggest th350 or 700r4 .
PostPosted: Tue Jan 22, 2013 4:15 pm
The Trooper rear-end is probably too wide also. Many members on here have stated that the stock Luv rearend will work fine with street tires and a mild V8.
PostPosted: Tue Jan 22, 2013 4:54 pm
So keep a 350 a 350 and stock rear end. I was not looking forward to changing that
Anyways. And a 700r4 sounds good also. Thanks I know what I need now.
PostPosted: Tue Jan 22, 2013 5:36 pm
A 327 would be fine for daily street driving also. I don't understand why someone would start with a 350 and make it a 327. I don't understand how one can do that.
So any reliable, good running small block Chevy motor will work. And for daily driving, I suggest the 700R4 because of the overdrive. It'll get better MPG on the road.
PostPosted: Tue Jan 22, 2013 5:37 pm
You will need the overdrive with the 4.56 gear that is probably in the rear . A narrowed 9 inch can be done for $750-800 if your frugal and handy .
PostPosted: Tue Jan 22, 2013 5:50 pm
A 327 and a 350 use the same block just different crank pistons and rods. Little more stuff but u get the idea a 327 can run hella rpm's if I'm not mistaken.
PostPosted: Tue Jan 22, 2013 7:01 pm
Still 23 cubes less and are you really gonna use that power up there in the RPMs and have a turd down low ?
PostPosted: Tue Jan 22, 2013 7:17 pm
Kinda wanna be able to pull hard on the highway but its still In The air. I dunno, If the 350 is good ill leave it but If it needs some work I might think about it.
PostPosted: Tue Jan 22, 2013 8:01 pm
If your buying the crank , pistons and rods then build a 383 for the same price and put 327 stickers on the valve covers , just sayin .
If on a budget Jegs has 350 crate engines for $1500 with 3 year /100,000 mile warranty with free shipping .
http://www.jegs.com/p/Chevrolet-Perform ... 6/10002/-1
PostPosted: Tue Jan 22, 2013 8:30 pm
Budget use the 350 block 400 crank with the mains turn down 400 rods and 350 pistons and u have ur self a 383.. Get ur self a s10 diff most come with 3.73or 3.42 ither one is good and use a th350 ull have pump gas 11sec truck .. I hate the 700r4 i have one in my s10 blazer with a 350 the pump on them suck..
PostPosted: Tue Jan 22, 2013 10:05 pm
So the stock rear end will hold up to a normal 350. What if I'm pushing a bit more what can I use that will fit right in. I don't wanna build a 9 inch or cut down an axel housing. Any other options?
PostPosted: Tue Jan 22, 2013 10:29 pm
ChevyToyR1 wrote:
Get ur self a s10 diff most come with 3.73or 3.42 ither one is good..
It bolts on.. No mods except for brake lines and drive shaft
PostPosted: Tue Jan 22, 2013 11:54 pm
Properly built, a 700r4 is a good trans. I had one in my s10 blazer (with a 327) I liked the trans, not the engine, lol...
PostPosted: Wed Jan 23, 2013 6:10 am
I thought the s10 rear end was wider than the stock rear end? Can I offset the wheels to compensate for the width and not go too far past the fender wells?
PostPosted: Wed Jan 23, 2013 10:24 am
Yes, and yes....
PostPosted: Wed Jan 23, 2013 10:26 am
Awesome I know where a junk one is.only problem is its welded spiders, is that okay ya think?
PostPosted: Wed Jan 23, 2013 12:42 pm
Or take an explorer 8.8 and buy 2 short side axles and cut 3 inches out of the long side and weld in spring perches and be done . They come in 3.55 , 3.73 or 4.11
PostPosted: Wed Jan 23, 2013 3:05 pm
If I were to cut an axel that's what I think I would do. Maby in the future.
