It is currently Sat Jun 13, 2026 12:03 pm
PostPosted: Tue Sep 07, 2010 8:03 pm
Been working on the Camaro a lot. New setup 406 sbc, Brodix track 1s, matching intake, demon carb, big comp cam, comp roller lifters, new crank, new flywheel, crank trigger, msd 6al, 2 step, coil, wires, hooker super comps, electric pump drive.
What y'all think?
No luv right now =(
PostPosted: Tue Sep 07, 2010 11:05 pm
Should scoot! Lemme know how you like that Demon carb. I was eyeballing them and I don't know anyone who's tried one yet.
PostPosted: Wed Sep 08, 2010 12:18 am
This is the 3rd setup I have ran it on and so far its been great. Awesome throttle response . I have heard a lot of people have bad luck with them.
No luv right now =(
PostPosted: Wed Sep 08, 2010 9:51 am
1" The crank trigger is hands down the most reliable timing set up for the money
2" I have had about 10 sucky Demons for every good one I have ran across. Usually machining trash from their less than stellar quality control, or the replaceable venturis sucking air around the outer edges from a loose fit...
